Ir para o conteúdo principal
O Asus Zen AiO Pro Z240IC é um computador desktop tudo-em-um (all-in-one) conhecido pela sua tela 4K de ultra-alta definição e disco rígido de um terabyte.
Replacement for cracked screen
I had a problem when opening the aio and I cracked the glass of the screen.
does anyone know if you can find the replacement for the external glass part? the screen that has the touch?
I cracked it when opening and everything works, but it has the cracked lines and I would like to replace this screen.
please point me to where I can buy it.
thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
A lot of times they will have different models of the glass itself with touchscreens. It would be better to remove the screen if you are comfortable with doing so and look on the glass (probably will have a ribbon cable attached to the glass somewhere) and read the model numbers there and do a search off that.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
gasguirre será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 19
Ao todo: 713
