My display backlight switch off after a few seconds
Hello !
I have a display HP La2405wg.
When I power it on, it will display a few seconds, and then the backlight is turned off.
I can still see (barely) the display so I guess the LCD is working.
I was wondering what could it be ?
Best regards,
Frederic
Mise à jour (24/04/2018)
Hi !
I tried with and without computer (2).
OSD works a few secondes too, I can also see it a little (barely) after the backlight is gone).
I opened the display and checked the board.
Here are a couple of pics:
The area on "T101" (transformer) and 2 diodes (D101 and the one next) seems like it heated a lot.
I removed the 2 diodes to tests them. They seems alive.
I measured the both transformer and I can see similar impedance on both (measure in circuit).
I think this area is called the "inverter" but I dont know how it works: I'm in electronics engineering, but have very very limited knowledge on displays...
The driving IC (SO14 package) seems to be an OZ9938ON (from what I can read on it).
I found this: http://dalincom.ru/datasheet/OZ9938GN.pd...
The board seems to be this one:
Any idea welcome :D
Esta é uma boa pergunta?
4 comentários
Hi @raymong ,
Do the OSD menus work OK?
What make and model computer is the monitor connected to?
Have you tried it with another computer to prove whether the fault is with the monitor or the computer?
por jayeff
Hi sorry! I'm new on Ifixit too :) I wanted to answser and I updated my question instead ;)
por raymond
Here is a picture of one of the backlight connector, there are 2 like this.
[image|1434147]
Any idea if I can check for shorts between some of those pins ?
por raymond
Replaced two capacitors (680uF/35V) on the left side of second photos, it should be work.
por fatfat0824
