Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1158 Perguntas Visualizar todos
Pergunta encerrada
Screen not responding after replacement.
I am almost done replacing a broken screen and am attaching the connectors to the logic board. I have worked with these type of connectors before, but after getting them all connected, when I plug the phone in and turn it on all that happens it it beeps to let me know that it is now charging, but the screen is dead. Everything was working before I replaced the cracked screen, so what could be the problem? I have checked the connectors twice and still nothing.
Thanks for any help,
John-Paul
Esta é uma boa pergunta?
Pontuação 0
1 comentário
check you have the right screen.. not a 3gs
por
Adicionar um comentário
3 respostas
Solução escolhida
Make sure the connectors are on, and then flip the silent switch on/off about twice and hold down both the home and the power button. Have the phone plugged in while doing all this. This is a hard reset and usually helps.
Worse case if it doesnt work, remove the board from the housing for about 5 minutes. attach everything and plug it in. This helps when I get a stubborn phone.
Esta resposta foi útil?
Pontuação 4
5 comentários:
Thanks,
This fixed my problem!
Have a great day!
por
Thank you, this fixed my (similar) problem as well!
por
Great! Please vote (left arrows) up the answer when it helps! Thanks!
por
its working its working, i love u man, from a happy irish man
por
:) please vote up if it worked for you
por
Did not work with either options
Pontuação 0
Thanks it worked great
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 4,301
