Ir para o conteúdo principal
The larger version of Samsung's flagship phone, the Galaxy S8+. Released in April 2017.
167 Perguntas Visualizar todos
Cracked screen half screen is white
I dropped my phone and in the middle of the screen all the way to the right edge there is a crack and now a horizontal line and from there down the screen is white static and I can't see anything but I can still click on apps. What is broken or need to be replaced?
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
4 respostas
my guess is the entire display. Unless you have like 5 specific machines that will put all your cheap separate display parts together properly, I'd just look into the easiest display replacement method possible, usually a $40-60 part, a whole display, lcd+digitizer/glass, sometimes they'll come with a mid-frame or whatever it directly connects to. Find videos on the DIY job, at least three to get familiar with every little step, trust me, I've wasted a lot of money on breaking new displays/glass trying to rush this stuff, make sure you know how to adhere the display to whatever it connects to like a mid-frame and/or bezel, what adhesive, glue and/or double sided tape, AGAIN know the steps to the very end before you attempt. Don't work on carpet. Maybe get one of those anti-static wrist bands.
I broke my last display screwing up the last step, stuck it down a hair off screwing it up then had to take it back off and broke it. Go slow. Good luck
Esta resposta foi útil?
Pontuação 0
1 comentário:
How much would that cost if I took it to a professional repair?
por
This is the same problem with me. My 10 Viking pro is broken so I used my Samsung Galaxy S8+. Soon I made a HUGE mistake. I took it to the store with me and my mom. We had no car so we had to walk. Soon when we were done getting groceries, I accidentally dropped it. I was embarrassed. It was already cracked, but it didn't have bad landing. Two days later I turned it off to get my little sister at are friends house. Soon I found her already on the porch. “Get in here!” I said. Soon I went back on the phone till it showed white on the bottom half while the top has solid black like my soul was. “I have no electronic now…” I said in my head. My mom won't let me play on her PS4 or her phone. My sister won't let me play on her tablet, so I take it in the mornings. I'm sorry this is not an answer. When I find an answer, I'll send it to
Pontuação 0
Mine it's not cracked but it's displaying half screen
Pontuação 0
I have a white screen how to fix it
Pontuação 0
Adicionar a sua resposta
Jene Bigness será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 32
Duração total: 14,164
