Ir para o conteúdo principal
Lançado em junho de 2017 como o sucessor do Surface Pro 4. Também conhecido como Microsoft Surface Pro 12,3". Número do modelo: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Substituição da tela do Microsoft Surface Pro 5 guide.
Just a thought.
por
Go for an iopener, otherwise it's too easy to damage the surface.
por
Adicionar um comentário
2 respostas
Solução escolhida
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
Imagem de Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).
Produto
Heat Gun
$29.99
Esta resposta foi útil?
Pontuação 3
I would use the iOpener or a heatmat.
Pontuação 2
Adicionar a sua resposta
Daniel Mossman será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 20
Ao todo: 1,684
