Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
300 Perguntas Visualizar todos
motherboard internal microphone pinout
I recently cut the mic from an old MacBook Pro 15" Unibody Mid 2009 and used it to urgently and successfully replace a damaged one in a more recent MacBook Pro.
now im close to fixing the older model I thought I would replace the mic just in case I ever wish to use it.... when I got the remaining cable and plug from the MB I discovered has 3 leads and not the two I was expecting.. all very messy I know.. yet anyone know the pinout on this?
ta very
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Hi Hop,
It’s look like the right black one on you picture is not connected.
https://www.ebay.com/itm/Genuine-Apple-M...
There you can see that only two wires go to mic. But if you want be pretty sure:
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Microphone
And little help ( what probably you don’t need ):
http://tim.id.au/laptops/apple/macbook/m...
por
thanks so much....... pdf is excellent
por
don't suppose you have similar pdf for late 2011 13in MBP?
por
Adicionar um comentário
1 resposta
Solução escolhida
Given the cost why don't you just replace the full assembly than dicker around with splicing the wires.
Here's the part from IFIXIT: MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Microphone
As for the wiring the two black wires are the mic and the grey is ground. You do need to wire all of the wires otherwise you'll get noise.
Imagem de MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Microphone
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
1 comentário:
2 seconds with a soldering iron on a totally disassembled computer vrs fifteen dollars and waiting for the post for a mic I may never use.... im going for the hack on this one... thanks so much for the colours ..
por
Adicionar a sua resposta
Hop será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 600
