motherboard internal microphone pinout
I recently cut the mic from an old MacBook Pro 15" Unibody Mid 2009 and used it to urgently and successfully replace a damaged one in a more recent MacBook Pro.
now im close to fixing the older model I thought I would replace the mic just in case I ever wish to use it.... when I got the remaining cable and plug from the MB I discovered has 3 leads and not the two I was expecting.. all very messy I know.. yet anyone know the pinout on this?
ta very
Esta é uma boa pergunta?
3 comentários
Hi Hop,
It’s look like the right black one on you picture is not connected.
https://www.ebay.com/itm/Genuine-Apple-M...
There you can see that only two wires go to mic. But if you want be pretty sure:
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Microphone
And little help ( what probably you don’t need ):
http://tim.id.au/laptops/apple/macbook/m...
por Rob
thanks so much....... pdf is excellent
por Hop
don't suppose you have similar pdf for late 2011 13in MBP?
por Hop
