Ir para o conteúdo principal
O Dell Latitude E6400 foi o notebook corporativo padrão de 14,1" da Dell, lançado em agosto de 2008.
Activating the Bluetooth wireless switch
I have been trying to tether my iPhone to my Dell Latitude E6400 using Bluetooth. When I click on the Bluetooth icon, it tells me to activate the wireless switch. How do I do this?
Esta é uma boa pergunta?
Pontuação 58
19 comentários
i have switched on the airplane mode so it stops all wireless connection,bluetooth...but i cant to off it i tried all known possiblities fn+signal symbol,setting al is greyed out
por Compartilhar
hello guys I'm here to help you guys
please update the drivers
and please refer the following link just copy and paste on the browser after downloading you can use Bluetooth and also can view in device manager
http://www.driverscape.com/manufacturers...
por Compartilhar
How can I instail my bluetooth?
por Compartilhar
I have dell latitude e6400 Laptop and having problrm with blutooth.. bluetooth indicater light is on but there in no any bluetooth icon anywhere in the laptop in divice manager or control panel etc
por Compartilhar
mine too
please help
por Compartilhar
Exibir mais 14 comentários
Adicionar um comentário
5 respostas
Solução escolhida
First, be sure you have the Bluetooth option; it is not standard equipment on your model. You should have a Bluetooth indicator light above the F1 key if yours came equipped with Bluetooth. There should be a key sequence marked for it on the keyboard. I believe it is Fn+F2 that will switch your Bluetooth wireless on and off. Your WiFi wireless switch is on the right, above the headphone and microphone ports (next to "Dell Wi-Fi Catcher" button).
Esta resposta foi útil?
Pontuação 40
14 comentários:
Good answer.....+
por Compartilhar
Thank You. It is working now
por Compartilhar
still cant find it
por Compartilhar
still bluetooth indicator light above F1 not on..
plz help me..
por Compartilhar
my light will not come on iv pressed fn+f2 as well
por Compartilhar
Exibir mais 9 comentários
Turn on your wireless from wireless button and bluetooth will also turn on with this.
Pontuação 15
1 comentário:
Vergo, read the comment made by Kevin McConnell (the OP), March 23, 2011. Good answer to a very old and resolved question
por Compartilhar
Firstly you need to make sure that whether your Bluetooth is properly installed and as far as the switch is concerned the check on you keyboard from F1 to F12 where you can see the Bluetooth icon. So all you need to do is just to press Fn key and then hold the exact Bluetooth activating key.
Pontuação 2
1 comentário:
bluetooth is not turning on in my laptop
por Compartilhar
you may not have the bluetooth driver installed. Go to dell support, look up the 370 minicard under wireless devices, and download that driver. Once it's installed you will have the tray icon where you can connect your bluetooth device. Here is a link:
http://www.dell.com/support/home/us/en/1...
Pontuação 1
2 comentários:
I have a Dell latitude e6430, and it did not come with a Bluetooth card. There isn't a Bluetooth symbol on my keyboard anywhere can I install one? And if I can will a Bluetooth card from a Dell Latitude 6400 be compatible?
por Compartilhar
You can always install a USB dongle to add Bluetooth functionality. And yes, they make WiFi cards that include Bluetooth so that is also possible. I'd go for a newer one since the lat e6400 is like 10 yrs old
por Compartilhar
i have a dell e6400 the blue bluetooth icon is on, bluetooth card is in, i have windows 10 i cannot find bluetooth software please help this is extremely fustrating
Pontuação 0
Adicionar a sua resposta
Kevin McConnell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 55
Ao todo: 266,547
