Ir para o conteúdo principal
Guias de reparo e suporte para o controle de jogos independente da Nvidia lançado em 16 de janeiro de 2017.
Nvidia Shield Controller (2015) touch buttons replacement?
So a while ago my 2015 1st gen Nvidia shield front touch buttons stopped working, and I thought it was a bad 12-pin cable. It turns out it's the touch buttons (nvidia button, home button, back button, and play button) that stopped working. I have searched far and wide for a replacement but haven't found anything. Can anyone direct me to where I can find one?
Thanks for responses in advance :)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Mine also stops working but it’s a firmware issue. Recently I found out, when I cut out the power by disconnecting the battery from a 2015 controller and plugged back in everything works like a charm until I reboot or shut down the console. So I made a workaround. I drill a hole on a controller and connect a switch to the battery. It was annoying the old way now I just hit the diy switch off and on and everything works fine
Regards
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matrucious será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 2,081
