Ir para o conteúdo principal
Which Part Isn't Working?
Hello. I have an iPhone 6, and about three months ago, Wi-Fi began to feel really weak, it would disconnect even when standing next to the router.
More recently, the front camera AND the ear receiver stopped working. ( I now have to put calls on speaker to hear them).
My question: is it possible that one broken part have caused all of these problems?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
No it wasn't dropped.
Is it possible to replace the flex?
por
Adicionar um comentário
3 respostas
Solução escolhida
The front camera and ear speaker share the same flex, so it's normal that both could fail at the same time. The WiFi antenna is in the same area but not physically part of the same flex. It's actually in the housing instead of embedded within the screen assembly. Did something happen to the phone recently, such as a heavy drop, a repair or contact with water? Those are the kinds of events that could cause multiple problems.
Esta resposta foi útil?
Pontuação 2
Esta resposta foi dada inicialmente para uma outra pergunta.
There is an inter connected antenna on the underside of the board that may need to be reseated. Unless you are extremely diligent with the screw and all of the small parts I would suggest getting some help with the repair.
If this doesn’t solve the issue there is also microsoldering options but we can cross the bridge on that after the antenna is checked.
Pontuação 0
2 comentários:
You mean to reseat the antenna. Not replace it? Can you please refer me to the guide.
por
here: iPhone 6 Wi-Fi Antenna Replacement it says replacement, but you can use this guide to get to the part.
por
Like Scott says replacing the wifi antenna is your first option ,it's common for this part to fail and cause weak wifi.
Pontuação 0
Adicionar a sua resposta
AaAa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 61
