Ir para o conteúdo principal
O AKASO KingPad A90 é um tablet de 9 polegadas com processador dual core. Ele possui 8 GB de armazenamento interno, executa o Google Android 4.2 Jelly Bean, tem câmera frontal e traseira, alto-falante traseiro e suporte para saída HDMI. Este dispositivo foi lançado em 31 de outubro de 2013.
How to replace screen on Prestigio Wize 3147 tablet
I bought a new glass touchscreen, I have unglued the edges of the broken screen using a hot air gun. The old screen is still attached by a ribbon cable at the top right corner, can't get to the fixing, maybe the display can be lifted out to get at the cable attachment? Or maybe get at it from the other side, via the wee door where the 2 sim cards are?? No obvious way to get it apart. Any suggestions? Thanks!! jake williams
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
My friend came up with the answer, after watcing this video,,,,,, https://www.youtube.com/watch?v=ySfbwUG6... ................ it's about a similar tablet.... the back prises off, using thin knife blades and similar levers...... i couldn't even see that there's a join, there's just a slight line in the plastic, but sure enough it came apart, and there's a socket for the ribbon cable with a locking tab that you can lift up with your thumbnail....jw
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jake williams será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 22
Ao todo: 588
