Why di I have to hold the signal light lever to make turn lights work?
Have to hold signal light lever so the signal lights will work. The lever does not lock in place. 1989 F-250 Ford Lariat
Esta é uma boa pergunta?
bfortune there should be a plastic 'trip' part that gets set when the indicator lever is is pulled up or down. This sets a tripping part that is contacted by a steering shaft projection (canceller) to trip the turn signal off when the steering wheel goes straight. Take a look on here as well as on here for a better understanding and how to possibly fix it. Instead of trying to fix it you can of course replace the whole assembly as well.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 31
Duração total: 529
1 comentário
Know what to do now. Great help. Thanks
por bfortune
