Ir para o conteúdo principal
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Why is it beeeping
The beep code is 1-1-1-1-1-1 th en turns off I've tried removing all the parts and I had a cpu that was the same one I switched th e cpus and still beeps. I know it's not the ram cause I just got the ram 2 days ago. I haven't taken out the cemos yet I'll try that but if anyone knows how to fix I need the awnser.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
@mcofficalplays what make and model is your computer? What motherboard is it? Did it have this issue before you replace the memory? Have you tried the old memory
por
@mcofficalplays
list out the make and model as mentioned from oldturkey03
check on your graphic card and power supply also.
por
My computer is the Brodcast pix slate g 1000 i tryed removing the graphics card and I got this without ram but,with the ram type
por
@mcofficalplays try opening up the casing, take pictures of inside mainboard, perhaps install a working graphic card and see if it boots up
por
Adicionar um comentário
2 respostas
Solução escolhida
The broadcast Pix slate G 1000 is not a typical computer. This is a highly customized machine with proprietary hardware for broadcast television video. I suggest posting on their forum for an answer.
Esta resposta foi útil?
Pontuação 1
1 comentário:
i will post there
por
Pergunta mais útil
If you just Google for your brand of motherboard suffixed by "beep codes" you may well find the answer.
Pontuação 1
1 comentário:
I can't it's a special motherboard made by the computer company that is the same one that made the computer.( The pc is a switcher)
por
Adicionar a sua resposta
McOfficialPlayYT será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 179
