Ir para o conteúdo principal
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
75 Perguntas Visualizar todos
My galaxy s5 active will only turn on with USB cord plugged into wall
my galaxy s5 active will only turn on with USB cord plugged into wall and i have to push the cord a certain way in the charging port. i have tried different batteries but it wont turn on unless its plugged in. then once it finally fires up it will stay on less than a minute than shut off. IN MADNESS I DWELL !!!!! PLEASE HELP
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Clean the charge port out as carefully as possible so as not to damage any pins. They usually end up full of lint and other crap from our pockets. If that has already been done then replace the charge port.
Follow this guide to replace the charge daughter board.
Galaxy S5 USB Daughter Board Replacement.
The new replacement part is available from here.
Galaxy S5 Charging Assembly.
The hint to me is this " i have to push the cord a certain way in the charging port.".
Imagem de Galaxy S5 (T-Mobile) Charging Assembly
Produto
$29.99
Esta resposta foi útil?
Pontuação 0
2 comentários:
Make sure you get the correct revision of the charging port daughterboard. There are at least four variants about. Use the wrong one and you won't be able to charge or use 3/4G.
por
Also 30 dollars is ridiculously expensive
por
You have tried several batteries. That they don't work shouldn't be dependent on the charging port connector. Have you tried using an external charger to charge one of these batteries up? It might not be worth replacing the charging port if you can get by with an external charger.
Pontuação 0
Adicionar a sua resposta
matt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 219
