Ir para o conteúdo principal
Screen and Battery replacement
I'm curious, I'm replacing the screen (it's shattered) and related components on my iPhone, (6s Plus) as long as I have it open I was going to replace the battery.
Question:
Can I replace both items in one fell swoop? Or should I replace the screen, boot everything back up, then replace the battery?
Thanks for your help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
first disconnect the battery, then the screen. you can then put in the new battery but leave it disconnected until you have the new screen connected
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank You daniel. I've replaced I've replaced batteries in two different iPhones. This will be my first screen replacement. I'll keep you up dated. Thanks again.
por
Adicionar a sua resposta
Leo Lambert Jr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 150
