Brother MFC-7860DW not turning on
My printer after being unplugged then plugged back will not turn on, I’m wondering if a fuse is busted, I need help to open it and check it or how to troubleshoot
Esta é uma boa pergunta?
Hi @otepd ,
Try this solution I've provided for a Brother MFC -J4510DW and see if it works on your printer also.
My Brother Printer EMFC-J4510DW won't turn on
According to the comments in the Chosen Solution it has worked on a lot of different Brother printers, both laser and inkjet models
Esta resposta foi útil?
Works for MFC-J5720dw printer - resets to factory default though
I found that these brother printers are very fussy about where they are plugged in.
First - Un plug it and wait 60seconds
Second - Plug it its own wall outlet, not a extension strip
Hit the power button, it should start up.
- James
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 24
Duração total: 10,471
