The Claw é um jogo de fliperama eletrônico de pequena escala com luzes LED piscantes. Esta é uma máquina de pegar doces e brinquedos projetada para uso doméstico.
I had the same problem; blame flimsy construction. In my case the gear, which was made of the world's cheapest plastic, had partially worn JUST enough to make the thing skip. A friend of mine 3D printed me a new gear and after some careful disassembly, reassembly, and a couple dabs of hot glue, it worked again.
@ninjashadow3
If you heard gears moving, you need to check if the traverse mechanism is engaged properly / blocked / broke. take some pictures.
The Claw Item Replacement
por Augustine
por Steve
