Ir para o conteúdo principal
Guias de reparo para o LG V30, lançado em setembro de 2017.
Screen replacement will it still be waterproof
If I replace the screen on my lgv30 will it still be waterproof or no?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi, I'm afraid to tell you that LG V30 will lose waterproof after repaired. We've tried add some waterproof glue on a repaired phone and test whether it could keep the waterproof feature, and it turns out that even you add the glue on it, the waterproof in still not insured. The safe way keep it from water damage is keep it away from water as possible as you can. And official repair would be recommended if your phone is still under warranty.
Good luck.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Dawid Perkowski será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 2,546
