Ir para o conteúdo principal
O BLU Vivo 5 é um smartphone Android produzido pela BLU, uma empresa americana de eletrônicos de consumo. O 5 foi produzido através de uma parceria entre a BLU e a Vivo Communication Technology Co. Ltd., uma empresa chinesa de tecnologia. O BLU Vivo 5 foi lançado em fevereiro de 2016.
Charging Port Not Working
So my device is most likely water damaged but is not showing to many signs of it being water damaged. My phone started to charge slower everyday and I do not know if it is the cheap charger being junk or the charging port is fried. The device will run normally and last normally under a full charge but takes 7 hours to get a complete charge. Is there a way for myself to find out what the true issue is without buying a cord to test my theory or pay a repair shop to diagnose my phone?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I have found the issue. The charger that came with the phone was garbage. All I needed was to replace the charging cable and adapter and now my phone charges at its original speed. For anyone reading this, make sure you get a good quality cable and adapter as a cheap one might present the same problem. Get a charger that says at least USB 2.0 and the adapter has the correct rated wattage on it. A good brand that I used was Anker and it is serving me amazing. The quality of the of the cable is amazing and it is braided which helps with durability.
Esta resposta foi útil?
Pontuação 0
The charger is fine, most of the time with the description you just made is due to the battery itself not being able to charge fast enough. Your battery may be so damaged it caused it to be near it's eol.
Pontuação 0
3 comentários:
The battery status according to many diagnostic apps and by my phone that the status of the battery is good. The battery does discharge properly to keep my phone running so I do not think my self it is the battery that is causing the problem. I cannot check that as I have to remove the non-removable backing off.
por Compartilhar
Hm..sorry, generally I'll try with another battery but yours being non removable means you'll have to pry the display off the chasis and such. Are you near for an upgrade, if so I guess just put up with the phone then.
por Compartilhar
Well I will not be upgrading for most likely another year or two. I intend to use this phone until it is just as fast as growing potatoes. Or the battery has a strokes and dies. Either or I will be having this phone for a much longer period of time.
por Compartilhar
Adicionar a sua resposta
Bomber_Bot será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 1,261
