Why is my router suddenly slow?
My router seems suddenly unable to go above 1MB/s speeds, on both ethernet & Wifi.
Edit:
So far, I've tried
- Power resetting
- Factory resetting
- Disabling Wifi altogether and plugging in through the ethernet to remove bandwidth stealers
- Upgrading the firmware to the latest version
None of the above things helped.
Esta é uma boa pergunta?
4 comentários
Hi @fayazbhai ,
Do you have a telephone service as well as an ADSL service on the line?
Check if the line is noisy. A line fault can slow down the speed.
por jayeff
I agree. That is a line service problem. Reset the thing back to factory specs. That may cure it... ONCE. Most low-end routers do not have recovery smarts. They simply fall-back to slow-mode. The reset will put it back to its normal speeds.
por Tom Shafer
@jayeff Connecting directly to the ADSL modem gives about 10mbps speeds.
por Fayaz Khan
Hi @fayazbhai ,
Do a power reset on the router, i.e. turn off power on router, wait for about 10 seconds then turn power back on, wait till it initializes then try it.
por jayeff
