Ir para o conteúdo principal
Guias de reparo e resolução de problemas para o HP Pavilion 13-s128nr x360, um laptop 2 em 1 da HP lançado em setembro de 2015.
How can I upgrade the RAM?
I want to know if I can do it and, if so, how to upgrade the RAM memory of my computer. Specifically I want to know the steps I need to follow and what kind of memory I need to buy.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @maupalo
Based on crucial website, there seems to have options to upgrade your computer RAM
http://www.crucial.com/usa/en/compatible...
Your HP - Compaq Pavilion 13-s128nr x360 Convertible
system specs as shipped
memory
Maximum Memory:8GB
Standard Memory:8GB removable
Slots:1 (1 bank of 1)
To confirm before you proceed to purchase the memory, shut down the laptop and flip to the back,
open up the screws behind to expose the mainboard, you should be seeing RAM slot compartment.
Remove the previous memory and add in the new one.
Check on the PC shops, which is selling RAMs, they might either help you to upgrade the RAM for you complementary or at a small fee, if you are not confident to do the job.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mauricio Palomares será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 1,081
