Ir para o conteúdo principal
O LG VX8550, ou LG Chocolate Spin, é um celular com recursos de câmera e multimídia que apresenta uma nova roda de rolagem. Ele foi lançado em 2007 e descontinuado no terceiro trimestre de 2008.
Cell phone, wont charge
MY CELL PHONE FOR SOME REASON WHEN I TRY TO PLUG IN THE CHARGER BECAUSE THE BATTERY WENT DEAD I HAVE TO WIGGLE THE PLUG IN THE PHONE TO MAKE A CONNECTION SO THE PHONE WILL CHARGE.NOW my battery went completely dead so i pluged in the charger now when i wiggle the plug to make a conection it wont at all now. i have to say i thaught it was the charger so the store i got it from one month ago they gave me a new carger but i still had the same problem only it wasnt too bad as long as i didnt let it go completely dead like i did this time.. i dont know if it is the phone wire port or the charger if any body has any advice i really would appreciate it thank you... JOE
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like the jack where the charger plugs in is either loose or has a short. I would take the phone in and have them check it. It has to be the battery or charger or phone jack and based on what you stated the problem looks like a loose connection.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I will add to that look for debris in the charger port and/or bent pins.
por
Adicionar a sua resposta
joe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 2,008
