Ir para o conteúdo principal
Um Passat totalmente novo, baseado na plataforma B5 do Grupo Volkswagen, foi lançado em 1998 na América do Norte.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
This question was migrated from https://meta.ifixit.com/Answers.
por
Adicionar um comentário
2 respostas
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Air flow and throttle show a short circuit .wiring okay
por
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Pontuação 0
Adicionar a sua resposta
Stephen Ryan Bearden Madison E será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 1,726
