Ir para o conteúdo principal
Segunda de sua geração, lançada em novembro de 2011, a Sony SLT Alpha-65V é uma câmera SLT (tecnologia de espelho translúcido) com montagem de lente Sony Alpha/Minolta.
Broken Pop-up Flash broken
I inadvertently SAT on my camera and broke the pop-up flash unit. It no longer locks down on the body but still produces a flash ! Is it repairable and if so, any idea as to cost or where to send it ? Is it self repairable given a spare unit ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @clumbsy ,
Here is a link to the ifixit Sony SLT Alpha-65V flash replacement guide.
This should be of some help to gain access to the flash assembly so that it can be replaced.
Unfortunately I have been unable to find a replacement part online, (you may have better luck) but if you live in the USA you could try contacting this supplier and check if they have the part or may know where to get it from or even the part number would be of some help.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your reply. I obviously was not totally clear in my question. The flash still works it is the pop-up mechanism that is broken (it will not latch down) and tends to hang on the connecting wires... cant make out from the guide if it covers the removal of the flash from the pop-up mechanism or if it is separately repairable. Does a replacement unit include the pop-up mechanism ??
por
Hi @clumbsy ,
Perhaps you should contact the supplier in the link and ask if it is complete unit, i.e.has both flash electronics and mechanical pop up section or whether it is obtainable as separate parts
por
Adicionar a sua resposta
George P Morris será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 974
