Ir para o conteúdo principal
Este é um tablet de 8 polegadas na cor azul claro, com câmeras duplas e voltado para estudantes e uso doméstico. Também conhecido como Nextbook Ares 8.
Tablet will not turn on
I can't get the table to turn on it shows that it is fully charged.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I forgot I had this model in a bottom drawer. It has been 3 or 4 years since I last used it. (Flaky power connector).
I started Finding out when I plugged in the supply It showed a red light that it was charging and then get this battery icon showed and it still had over 75% battery power. It took me several attempts to start it. So I just let it charge and when it was charged after several minuets I just gave up. Then I tried to start it and behold A word Nextbook showed up on the screen for a several minutes (7+). Then It changed to a scrolling display with the same Name. So again I just left it do its own process for several Minutes More.
Then it started to work!!!! So be patient. Now i started to get the settings and more. Experiment, there was more on the tablet than I knew about. Hope this note Helps!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tom Acosta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 11
Ao todo: 412
