Ir para o conteúdo principal
Laptop ASUS X550LB-DS71 com tela de 15,6", processador Intel Core i7 4500U, 8 GB de RAM e HDD de 750 GB
CPU cooler not working/detecting?
My laptop's CPU is overheating and throttling with the slightest load, firefox or even chrome with a couple of tabs opened, utilization is as shown in the picture.
Imagem
Imagem
I disassembled the laptop, cleaned out the fan properly, tested thermals again, with the same load, temps lowered about a 5 to 6 degrees on average, but the pc is still running ridiculously hot.
My question is this, is there some software to control my fan speeds or do i need to replace the fan ? (mind you that through aida64 and speedfan I did not get any info regarding the fan's RPM)
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
The heat sink may be liquid filled and may have leaked. Look at step #8 of this guide at the crimped end of the heat sink. Look for an oily type of residue on the logic board where the liquid may have dropped. If you see it, replace the heat sink and thermal paste.
Substituição da placa-mãe do ASUS X550LB-DS71
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
tom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 28
Ao todo: 422
