Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930.
425 Perguntas Visualizar todos
Phone dies at 70% with new ifixit battery
Hi yall!
So I swapped out my phones battery with an ifixit replacement about 2 weeks ago and it was working great up until a few days ago. It just shuts down at around 70% and needs to be recharged from 0%. There was one time where I put it on the charger after it died and it would read 69% but would keep dying instantly unless it reached 70% capacity.
This happens multiple times a day and my phone is useless most of the day. Is there any way to fix this? I also still have the original Samsung battery but I bent it a little bit while removing it. Is the original battery safe for usage until this gets sorted?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Did you follow the instructions correctly that came with the new battery? Like charging it up to 100% and let it drain to 5% and then charge again?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Battery is faulty. Lithium-ion batteries don't need calibration.
Esta resposta foi útil?
Pontuação 3
1 comentário:
OP, if you bought from iFixit, contact support (help.ifixit.com) and they should replace it.
por
I am having issues as well. In the last few days is has been discharging fast. I am using the battery saving mode on phone but still dies fast. I had 18% this morning and it shut down. I have contacted support awaiting a reply. I installed this about two weeks ago along with a new camera lense glass.
Pontuação 0
Faulty battery send it back, You should get a refund
Pontuação 0
Adicionar a sua resposta
Jesus Valenzuela será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 786
