Ir para o conteúdo principal
Repair guides for a large selection of Kodak digital and film cameras.
260 Perguntas Visualizar todos
lens obstruction error help
i have a problem.my camera is a kodak pixpro az251 i'm getting lens obstruction error trying to figure out howv to fix it .asking to re-start camera nothing happens.can someone help.ty in advance
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Solução escolhida
tornadoman1955 it is entirely possible that this is caused by a stuck lens. Follow these attempts and see if you are getting somewhere. If not, it is most likely you will need a new lens assembly.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Mine is stuck out what should I do about this?
por
@Blair B. same situation,same link just stuck on the track for the retraction. If the link does not provide a good solution for your camera, you will have to replace the lens.
por
Pergunta mais útil
Hi,I bought a Kodak pixpro AZ252 camera from Walmart and I put the batteries in and also a
(PNY Elite 16GB SD Card) and when I turned it on it said Lens obstruction Re-start camera and I don’t know what to do or how to can you guys help me!
Pontuação 2
1 comentário:
Mine is doing the same thing!
por
My Kodak camera has an obstructed lens and I dont know what to do. Please help!
Pontuação 0
Adicionar a sua resposta
tornadoman1955 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 20
Últimos 7 dias: 242
Últimos 30 dias: 1,025
Duração total: 19,912
