Ir para o conteúdo principal
Alto-falante Bluetooth da Brookstone, lançado no final de 2013. Teve recall em 2018 devido a problemas na bateria.
How do I open the grill?
I have no idea why, but the speaker seems to making a cracking sound on higher volumes. I believe it's from the bass driver. I am not certain if this is from the beach sand. I have trying for the past 4 hrs to remove the grill with no luck. Any help would be greatly appreciated.
I have removed the bottom end, the charging/aux port and the chrome around the start button.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
It’s been recalled as a fire hazard. See if you can get your money back first:
Brookstone announced the recall of 164,000 wireless speakers because of the risk of fire associated with their lithium-ion batteries.
The affected model is the Big Blue Party, a large indoor-outdoor speaker that was sold by major U.S. retailers and websites from December 2013 through August 2018 for about $200. Consumers should stop using the devices immediately.
Brookstone filed for Chapter 11 bankruptcy protection earlier this year, complicating the process for consumers to obtain a partial refund.
https://www.consumerreports.org/recalls/...
Esta resposta foi útil?
Pontuação 2
Sounds like you have most of it, now use a small flat head or flat plastic they use in removing parts in car, work around top where grill is..turn speaker upside down, if loose grill should slide down..
Pontuação 0
1 comentário:
can you make a video please
por
How to open brookstone?
Pontuação 0
Adicionar a sua resposta
Sanjeev será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 1,851
