Ir para o conteúdo principal
A powerful workstation laptop that fits into a portable package. Has multiple ports and connectors for a portable work environment.
7 Perguntas Visualizar todos
Is upgrade to m2 ngff ssd possible?
Hi,
I have an hp 8740w. I want to add on it another m2 ngff ssd 32gb to install on it linux, to not touch the main drive.
I want to know if this will be possible, considering that i will use ngff m2 to pci-e converter.
I also want to know if there is any way to install it full separately and not touch the windows mbr.
Lastly i want to know how safe is to use this converter for the laptop logic board?
The converter is that here:
https://www.ebay.com/itm/New-M-2-NGFF-SS...
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Your system has a standard 2.5" SATA drive. Where where you planning to install the M.2 drive?
Here's the service manual EliteBook 8740w
Esta resposta foi útil?
Pontuação 3
9 comentários:
Thanks @jayeff - corrected!
por
Hi @danj ,
All's good.
Cheers.
por
Thanks for your answer
I plan to install it on mpcie slot that have the WWAN 3G modem. And I find the adapter above. I also have already install a bigger ssd for my main OS , but i need separate ssd for the Linux. I read and this slot is mpcie, but i cant find anywhere if the adapter above is legit and safe to use.... I want to install m2 ssd 32gb that I randomly buy.
por
It likely won't work as the systems BIOS does not treat the slot as a generic PCI slot. Besides the phyical size of the adapter & SSD will exceed the space location the modem takes.
You do realize you can partition a HDD or SSD with multiple partitions which can support different OS's then using a boot loader to offer a means to select which OS to boot up makes more sense.
por
Yes , but this will update my MBR... I want to have it on another physical drive to not be single point of failure.
I will go with plan B and remove the dvd and install SSD :( . I like to have the dvd here! Then I will try to install Clover or Refit on that to check if will work. I hope that will work....
por
Exibir mais 4 comentários
Adicionar a sua resposta
ssavva05 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 15
Ao todo: 2,837
