Ir para o conteúdo principal
Complete repair manual for the PSP Go, including battery upgrade and display repair instructions.
89 Perguntas Visualizar todos
My PSP GO was bricked!
What can i do to repair it(Blue screen of Death)?
Flash0 / font accidentally deleted :(
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Does it just boot to a blue screen?
por
Adicionar um comentário
3 respostas
Solução escolhida
Make sure your charger is plugged in and press the O button to repair and restore default settings.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
If you are actually running a CFW on the PSP, than you should be able to boot it into recovery mode holding the right bumper, while turning it on. If you were using a HEN, and don't have a CFW installed, then you are kinda stuck with a brick, and might want to consider selling it for parts.
*EDIT* If you are using Custom FirmWare (CFW) and can boot the PSP into recovery mode, using the method above, and you can scroll over to Advanced>Toggle USB (flash0), connect it to your computer via USB, and replace the font file you deleted.
Pontuação 3
1 comentário:
CFW = Custom Firmware - HEN = Homebrew ENabler: Basically if you are running stock firmware you are not able to get around Sony's limitations it is a paper weight. Unless you have CSW, Flash0 / font accidentally deleted :( = paper weight
por
I concur with ABCellars.
To clear BSOD try pressing o
The PSP will then attempt to repair itself by re--installing default settings to flash.
Pontuação 1
Adicionar a sua resposta
LORD MK será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 36
Duração total: 13,358
