Ir para o conteúdo principal
Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Perguntas Visualizar todos
Is it safe to give corroded Xbox One board an alcohol bath?
Can I soak a Xbox One motherboard with corrosion in 90% rubbing alcohol? It has tough corrosion I can't get off with a wipe. Just wanted to make sure this was safe, thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hello Reed,
Yes it is totally safe to soak the board in alcohol so long as it is not energized. Be sure to air dry it or use a blow dryer on it to evaporate the alcohol before plugging it back in. Alcohol will not however do much to the corrosion itself but you probably should use a brush to loosen any corrosion while it is submerged. Do NOT use water at all, at anytime or the unit will not dry out very good and the corrosion will grow!
You could also use a pencil eraser to remove the corrosion.
Good luck, I hope this helps.
Rich Lilja
Esta resposta foi útil?
Pontuação 1
1 comentário:
I thought so! I appreciate the confirmation.
por
Do you mean sticking the entire motherboard in isopropyl alcohol to soak? and for how long?
Pontuação 0
Adicionar a sua resposta
Reed Crosby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 30
Duração total: 1,751
