Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2376 Perguntas Visualizar todos
What are the symptoms of water damage?
Hi, recently i had accidentally spilled a whole cup of ice green tea latte on my iPhone. I immediately cleaned off as much liquid as i could and the iphone seemed to be functioning fine. ( For the next 4 hours)
However, after charging the phone and unplugging it, it suddenly became very hot(approx 60 degrees celcius) and the battery drained extremely quickly. I was watching the phone and it was dropping 1% perhaps every 20 seconds. I had made sure to turn off all back ground tasks, wifi and 3g, but it was still getting very hot.
Even after turning off the phone, the bottom left area of the phone stayed at the same temperature for about 1 hour, which is really making me concerned.
Could the liquid have somehow screwed up the battery and caused it to drain and produce lots of heat very quickly?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
Yes it could and before going any further, I would most certainly disassemble the phone and clean it with my favorite, isopropyl alcohol and clean all corrosion and debris. After that I would DEFINITELY replace the battery and re-evaluate from there. ALWAYS LET IT DRY AND DISASSEMBLE BEFORE TRYING TO TURN IT ON.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Wai Soong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 5,157
