Ir para o conteúdo principal
O Sony Xperia Z3 Compact foi lançado em setembro de 2014.
Vertical artifacts after replacing display
I had a broken digitizer and tried to replace the screen (LCD+digitizer)
So cable connected and tested -> Working
Glue added, cable reconnected and slightly pressed on glue while trying to get that cable to bend the right way. When everything was in place, I tested the display again and found suddenly vertical lines extending from bright (e.g. white) elements shown over the whole height of the display.
This now happened twice to me and I can't figure out, what I may have done wrong.
Any ideas?
Start:
Imagem
Kinda invisible:
Imagem
After boot
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Double check the connection and the ribbon cable to the LCD itself, it may have become damaged.
My guess is the ribbon cable directly coming from the screen somehow got damaged during installation.
That looks like ribbon cable damage / bad connection.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Visually inspected but nothing found there. Very strange
por
Adicionar a sua resposta
Alex Grund será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 522
