if it is lost can I track to get it back
i lost my jbl and cant find it is there a way to track it?
Esta é uma boa pergunta?
Hi @joshlange724 ,
If you renamed the device and it is still turned on and it is still working you could try and see if it appears in your phone's BT list.
You'd have to be within 30' of it of course.
If it has been turned off or the battery has died (it only lasts for 20 hours when playing music so maybe a bit longer when it is not) then there is no way that you could track it.
Esta resposta foi útil?
thank you so much
Hey I lost my speaker at my friends house how do I find it
@Zach attack Jackson
Do what the answer above says.
If it appears in your phone's BT list it is somewhere within 30' of the phone so you will have to start looking for it.
If it doesn't show in the BT list then it is either off, has a flat battery so you still will have to look for it or is not there.
Hi my jbl xtrime 3 was stolen, can it be tracked?
The answer above shows what can be tried - so probably not as it is doubtful that it would be still on and within 30' of where you are.
Hi @Rick Miner
Are you sure that they're not only shown as listed in the BT list rather than suddenly appearing i.e. remembered from a previous time?
Try "forgetting" or “unpairing” the headphones in the BT list and then see if they show up again.
If they do show up again either the battery is not dead and it is switched on or there is another device with the same BT name nearby that is turned on
If the battery is dead or if is switched off there is no power for the BT chip in the headphones to signal anything
i lost mine i am SOOOOOOOOOOOOOOOOO MADDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
Hi mate, i'm not expert on this whole finding devices via bt but chances are it's completely lost. one of your only possible solutions is to retrace your steps and find where you last used it.
Últimas 24 horas: 50
Últimos 7 dias: 391
Últimos 30 dias: 1,489
Duração total: 59,019
8 comentários
hey so I’ve lost my JBL flip 4. how can I find it. it has ben gone for like 10h.
is there a way to find or should I just forget about it???
por ali
I have a question about bluetooth device tracking! If your bluetooth device such as headphones or speaker is lost or stolen and let's say that the battery is dead or the device is turned off is there any way that it can still be tracked? I've had some bt headphones come up missing and can't find them!!
por Rick Miner
I lost my JBL flip 4 speaker in teal I can’t find it anymore
por Sarah Manning
@Sarah Manning
See the Chosen Solution below.
por jayeff
Hello I've lost my JBL speaker someone block into my car and l dont know who so is it possible to track it and find it?
por Nafe Phiri
Exibir mais 3 comentários
