Ir para o conteúdo principal
Rogue G10 10W 1x3.5 Guitar Combo Amp. A compact amp perfect for beginners or practicing. The Rogue G-10 guitar amp produces a variety of tones in a compact size.
3 Perguntas Visualizar todos
Turn on loud "Burb" then no Sound
I moved recently and my amp was in storage for several months (was suppose to be temperature controlled).
The amp is actually a Rogue 120 SC but though you could help.
When I turn it on there is a loud "Blaap" and then no sound.
Is it possible the speakers (2X12) are blown ?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@scotia1 sure it could be the speaker. Just quickly wire another speaker to the existing one and see if it does play. However, I am always concerned with the audio IC. I would suggest that you take a couple of pictures of your circuit board and post those with your question so we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that. Make sure you have a multimeter handy to measure a few things once we see what your amps board looks like.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jim será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 279
