Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Has anyone installed a SSD in a A1176 Mac Mini1,1?
Hi,
I haven't been able to find a successful installation description of a SSD in a A1176 Mac Mini1,1. Can anybody confirm it is possible? Can you recommend any SSD model?
Thanks,
Igor.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
4 respostas
Solução escolhida
An SSD drive is physically exactly the same as a regular SATA drive, with the same SATA connector. So as far as installation, there is nothing specific to SSDs, and you can therefore use the guide for installing a regular SATA into an A1176:
Mac mini Model A1176 Hard Drive Replacement
Esta resposta foi útil?
Pontuação 6
It's not a god idea to put the ssd where the optical drive is. That bus is very slow and will cripple your SSD speed. I believe the optical drive is on a PATA bus.
Pontuação 1
I just installed a ssd in my Mac mini with a 1.86GHz CPU.
It was very easy, the hardest part was taking off the top.
Once the ssd installed I just booted off my Snow Leopard DVD and done.
What problems are you having?
If you put your orignial HD into a USB enclosure you can hook it up and boot off of it first.
You will see the ssd as a attached drive in Disk utility program.
Format the ssd and install new OS.
Pontuação 0
Hi, is it possible to remove the optical drive and replace it with an SSD ?
Pontuação 0
Adicionar a sua resposta
Igor Santos será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 4,131
