Ir para o conteúdo principal
A redesigned Pathfinder went on sale in late October 2012 as a 2013 model. Just like the second generation Pathfinder, it once again moved away from a body-on-frame, truck-based SUV and adopted a unibody design.
12 Perguntas Visualizar todos
Help! My car stops accelerating!
My 2013 Nissan Pathfinder will not do anything when I push on the accelerator sometimes and the rpms are not moving at all either. Their are no check engine lights that come on, so I have no clue of what to do. Any suggestions?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@sing74 just because the Check Engine light is not on does not mean there are no codes on the OBD. I suggest you start off by having it scanned. Let us know if there is any code that may have popped up.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Some places like AutoZone offer free computer readouts.
por
I will go there tomorrow.
por
Did you find anything out?? My 2013 Nissan Rogue is doing the same thing! But only when I’m on the interstate needing to go faster.
por
Adicionar a sua resposta
Samantha será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 360
