Ir para o conteúdo principal
Informações e guias de reparo para a versão atualizada do Retina MacBook de 2015, lançada no início de 2016. Modelo A1534 / EMC 2991
A1534 MacBook 12" not charging. USB C port was replaced.
Hello I have a 2016 m5 12" macbook. Purchased a new USB C port from here, replaced, and still not working. The old USB C was really bad, dinged up, had some black goop on it, covering the connecting rods.
Anyway, still not working. I tried to d/c battery and plug in, and check the white LED on the logic board, and that is not going off. Any suggestions?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Try another USB C port, might be faulty if the original one was in bad condition (since this sounds like the cause of the issue). If still not working, try the DC flex. Does it just say "battery not charging" with the charger plugged in, or something else?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Pol será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,588
