Ir para o conteúdo principal
Repair and support for ceiling-mounted bladed fans.
37 Perguntas Visualizar todos
My Ceiling fan only make humming sound but not moving, Light works.
Ceiling Fan light is working but fan only making humming sound but not moving? I have changed capacitor, checked pull switch and forward-reverse switch. Don,t know whats the issue here.
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
3 respostas
Pergunta mais útil
Does it spin easily by hand when off? When on and humming, try and get it spinning by hand. Does it take off and start spinning? If so your capacitor may be bad out of the box (rare but happens) or might be the wrong capacitor. If it doesn't, or doesnt spin freely like it normally does, then the motor might be bad/have bad bearings.
Esta resposta foi útil?
Pontuação 1
3 comentários:
I have this problem. My fan spins easily by hand. Motor hums and changes when speed is changed but fan will not run. It has been this way for a year. Last year I went outside came back and fan had started working. Just turned it off to dust and it will not run. Still spins easily.
por
@fredric2 sounds like you need to open it up and check the capacitor. Alot of fan capacitors are square with up to 5 wires.
por
Thank you. That is what I was thinking. Nice to get a second opinion.
por
It can also be a problem with the switch connection make sure all the wires are connected properly and make sure the switch is working 100%
Pontuação 1
2 comentários:
Thank you. I'll look into that also.
por
Found the problem was with the direction switch. When I change for the season I can work the switch a couple of times and it will start working.
por
I don’t think it is a switch problem. When I change speeds I can hear the hum change. I took the light kit off to look at the capacitor. I ordered a new capacitor and like magic the fan started working again. I have a new capacitor. Next time it doesn’t start I’ll replace it. Until then ‘if it ain’t broke’.
Thank you for your guidance.
Pontuação 1
1 comentário:
I found my direction switch was the problem. I can switch directions a couple of times and the fan will start working.
por
Adicionar a sua resposta
Vikram Raj será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 19
Últimos 30 dias: 100
Duração total: 1,080
