Ir para o conteúdo principal
O Golf Mk4 foi lançado pela primeira vez em agosto de 1997, seguido por uma versão notchback (VW Bora ou, na América do Norte, novamente VW Jetta) em agosto de 1998 e um novo Golf Variant (perua) em março de 1999.
Automatic transmission problem - delayed shifting
The problem is that when I start driving I spidometer stays at 0, and then at some point it "jumps" and shows real speed, in that moment the transmission shifts to next shift.
Also I hear a lot of banging when shifting, so do you have any idea what is happening? One more thing, when I connect car to diagnostics I get g68 error.
Sorry for my bad English
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There is a TSB 01-07-09 for your vehicle covering the G68 speed sensor. A faulty connector wiring is apparently the problem.
Go here and you can read about it yourself it also instructs you how to fix it. But at least it will give you some good information.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks a lot for response. I've tried to find where the sensor is, but unfortunately I couldn't find it, I've tried on the internet and also with autodata 3.38, but nothing. Can you help me somehow?
por Compartilhar
Try this thrhttp://forums.ross-tech.com/showthread.p..., and read through it. Also has a diagram and written location and instructions.
por Compartilhar
Adicionar a sua resposta
Enis será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 24
Ao todo: 2,834
