Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Perguntas Visualizar todos
MacBook overheats and fan goes off while I play games.
Since I play games such as the Sims 4 on my Mac, it will sometimes overheat (I usually play it with my computer on the table but sometimes in my lap) and around the top left area of my keyboard will get pretty hot.
The fans usually go off and it's fine, but is this an issue? Should I play the game less for my laptop's sake?
What should I do? Please help!! My computer is only 2/3 months old!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Its hot around the top left as that is the fan exhaust. for reference, keep it between 50-95F (10-35C) apple says.
Esta resposta foi útil?
Pontuação 1
I think 3D games is not fit macbook air, try 2D games or buy a laptop with a independent video card.
Pontuação 0
Macbook's aren't great gaming computers unfortunately, I wouldn't suggest using it to play games on as it may blow a circuit.
Pontuação 0
2 comentários:
Yep, that's why I stopped. My fans would go off when it wasn't hot and it'd have problems shutting down, so after I stopped playing games for a while none of that happens anymore.
por
I've gotten away with Sims 3 on my 2011 13" Pro. It's the Air that has issues - the Pro has no problem with moderately heavy games. Sims 4 also works, but I need to run Legacy Edition due to Metal 2.
3 ramps the fan up more then 4 too, which is surprising. That said, it runs loud since I set it to high.
por
Adicionar a sua resposta
Morgan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 2,215
