Ir para o conteúdo principal
iOS 11 - option for lock screen on off when cover closed missing?
As we all know the power button doesn't work without transferring the ic chip by the home button after replacing the screen.
In iOS 10 there was an option in the display settings to disable the screen turning off when the cover was closed and that would solve the lock button issue while you tested the new screen etc.
Where is that option in iOS 11, I can't find it anywhere.
Esta é uma boa pergunta?
Pontuação 1
5 comentários:
Anyone have an idea?
por
Are you using a real smart cover or a 3rd part smart cover? There was a mention that on the iPad 4, the option as of iOS 11 only appears if it detects the magnets attaching the cover to the iPad.
por
Good idea, thanks. Tried that but no go, the option is still nowhere to be found.
por
Put on assistive touch in general settings. Click on device when installed. Then click on lock screen. Magnetic shutdown does not exist on latest and newest iPad, Shame on apple! Brian
por
I have this problem on my iPhone 7plus the option isn’t there
por
Adicionar um comentário
3 respostas
Put on assistive touch. Click on to device. Then tap lock screen. No other way!
Esta resposta foi útil?
Pontuação 0
Settings > Display & Brightness > Lock/Unlock > On (Green)
Pontuação 0
I have an iPad 4 iOS 10. In Display Brightness the only option I have is Auto-Lock with settings of 15 mins to never. No off on lock setting available
Pontuação 0
Adicionar a sua resposta
workingshane será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 41,636
