Ir para o conteúdo principal
O Motorola Moto Z Play (números de modelo XT1635-02, XT1635-01 e XT1635-02) é um smartphone droid lançado em setembro de 2016. O Moto Z Play pode ser facilmente distinguido pela palavra “moto” posicionada na parte superior e pelo botão home quadrado posicionado na parte inferior da frente do celular.
No touch response after screen replacement
I replaced a screen with a cracked LCD. After replacement touch is unresponsive. During startup, I am prompted to enter my password and after a few seconds I can do so. Once started up, the screen comes on, but I can not unlock the screen. It appears to respond to touch, because the notifications change color when selected, but it does not unlock or prompt me to put in my code to unlock. Help!
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Only works now if I'm touching the screen with two fingers
por Compartilhar
hey did you get a solution to this? I am facing the same issue
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
Hey Casey!
Incompatible screen. Moto Z Play is a difficult one to find good parts for. Have to make sure the flex configuration is exactly the same as on the original or else it either doesn't work or only works with two fingers like you mentioned.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Great! I am having the exact same issue... Anything that can be done to fix the two finger operation?
When I ordered the LCD screen on eBay, the description said the part was for Moto Z Play XT1635. There was no -01, -02, -03 suffix. So I believed it would work with all of them. I have XT1632-02.
por Compartilhar
Adicionar a sua resposta
Casey Reynolds será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 1,495
