x-box controller not connecting to console
on/off light flashes but dose not connect to console . was working earlier. changed batteries. did not help
Esta é uma boa pergunta?
You should manually pair the controller to the Xbox. Use this link to help you.
Esta resposta foi útil?
tried your link. did not work.. I have had my x-box 1 for about a yr. the controller was working earlier in the day, turned x-box off tried to turn it on a couple hrs. later. it did not turn on the console. I turned console manually than turned on controller. the on/off button just flashed. changed batteries. did not help.. stumped :(
Well I would just assume the controller is done in for and buy a new one. Microsoft doesnt say much about this.
i am also having this problem. .with all 4 of my controllers..none of them will connect..fresh batteries nor resyncing did any good. .worked absolutely perfect last night
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 3,714
My controller is not sync with xbox 360 even I attempted alot to restart, sync button press for both controller and console but unable to find solution.please help even I refixed hard disk also
por maryam waseem
