Ir para o conteúdo principal
O HP Pavilion modelo dv7-4285dx é um notebook produzido pela HP.
How to clean the fan
My laptop is overheating and i can feel the heat through the case and so l eventually came to the conclusion that the fan is not working but because dust is trapped in the machine. And originally, i was planning on taking it to a computer store so they could clean the fan but I'm trying to save a dollar or two by doing it myself.. Does anyone know how to go about doing that, safely? Because i don't want to destroy my laptop. Thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Unplug. Switch off. Let it cool down for tens minutes. If it is really dusty strip it down to Step 12.
Substituição do LCD do HP DV7-4285DX
If you are not confident to take it apart. Just use your vacuum cleaner on the rear & top vents. Preferably with a small brush attachment (if you have one)
Esta resposta foi útil?
Pontuação 0
I applied colgate on my CPU while I was cleaning my motherboard with spirit. After that my laptop could not switch on and the fan is not even turning around. What should I do? Can it be reversed
Pontuação 0
Adicionar a sua resposta
AJS será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 15
Ao todo: 972
