Ir para o conteúdo principal
Lançado em 2012, este laptop possui um processador Core i7, uma placa gráfica Nvidia 620M dedicada e um display eletrônico de 1080p.
fan working too much
Hello,
I bought some days ago a zenbook ux510ux , it is a nice device, it works fine, but i m afraid something is wrong with the fan, it is working almost all the time, even if I do nothing or just whaching on youtube etc. ,I need to know if is it actually a problem. It is really annoying sometimes.
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @drvip ,
Check that the fan exhaust vent on the side of the laptop is clear and unobstructed.
Use a vacuum cleaner on low suction to clear vent if blocked.
If it not blocked or the fan still runs all the time after the vent has been cleared, open Task Manager (right click on taskbar and select it) and see how many processes are running etc. The CPU may be doing a lot of things (maybe too many), in the background. What OS is installed in the laptop?
If that looks OK then you may have to disassemble the laptop and clean the fan and maybe apply new thermal paste to the CPU and see if that helps at all.
Here is a link to the ifixit Asus Zenbook UX32VD repair guides, which should be of some help.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
vladimirposmag será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 25
Ao todo: 1,512
