Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
MacBook doesn't close properly. Not aligned.
Macbook doesn't close properly. The screen part isn't aligned properly with the bottom part when closing the macbook. Can't fully close it anymore.
Update (02/17/2018)
@danj
The hinge piece has been broken off.
Do I have to buy a new screen or can I solve it in another way?
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Did you bang the system or drop it?
por
Dropped it, but was a long time ago. Few months. Had no problems then.
por
Adicionar um comentário
1 resposta
Solução escolhida
Depending on what happened you may need to replace the hinges or maybe just re-align them.
Follow this IFIXIT guide: MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement Jump down to Step12 to see if loosing the hinge will allow you to re-align it. If the hinge has failed (galled up) then you'll need to replace one or both.
Esta resposta foi útil?
Pontuação 5
Adicionar a sua resposta
Maxim Martin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 6,442
