Ir para o conteúdo principal
MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement
O que você precisa
  1. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following P5 pentalobe screws securing the lower case to the MacBook Pro:
    • Eight 3.0 mm
    • Two 2.3 mm
    Pergunte ao FixBot
    Comentar
  2. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 2, imagem 1 %32
    • Lifting from the edge nearest the clutch cover, lift the lower case off the MacBook Pro.
    • Set the lower case aside.
    Pergunte ao FixBot
    Comentar
  3. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement, Battery Connector: passo 3, imagem 1 %32
    • Peel back the warning label covering the battery connector.
    Pergunte ao FixBot
    Comentar
  4. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 4, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 4, imagem 2 %32
    • Using the flat end of a spudger, gently pry the battery connector straight up out of its socket on the logic board.
    • Bend the battery cables back and out of the way, ensuring that the battery connector doesn't accidentally make contact with the logic board.
    Pergunte ao FixBot
    Comentar
  5. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement, AirPort/Camera Cable: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Use a spudger or tweezers to pry the three AirPort antenna cables straight up off of their sockets on the AirPort board.
    • The cable connection points are fragile. Be careful to lift only on the connector, and not on the socket or cable.
    • To reconnect, align the connector carefully into position over the socket, and press it down firmly with the flat of your spudger.
    Pergunte ao FixBot
    Comentar
  6. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 6, imagem 1 %32
    • Use the tip of a spudger to push the camera cable's plug toward the fan and out of its socket on the logic board.
    • The plug in the photo has six connections, but some models have twelve connections. The process of removing the plug from its socket is the same for both.
    • If the camera cable's plug won't come easily out of its socket on the logic board, fold back the rubber cover over the fan to gain access to the cable, then gently pull on the cable while using the spudger to gently push the plug out of its socket.
    • Be sure to push parallel to the board, first on one side, then the other, to slowly "walk" the plug out of its socket. Do not pry up, or you will damage the socket.
    Pergunte ao FixBot
    Comentar
  7. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 7, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 7, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 7, imagem 3 %32
    • Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
    • Slide the spudger underneath the length of the cover, releasing the adhesive.
    • Lift the cover and flip it back so that you can access the cables underneath.
    Pergunte ao FixBot
    Comentar
  8. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 8, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 8, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 8, imagem 3 %32
    • Use your fingers to pull the AirPort/Camera cables up off the fan.
    • The cables are adhered to the fan, so peel them up carefully to avoid damaging them.
    • Carefully de-route the cables from the plastic cable guide.
    Pergunte ao FixBot
    Comentar
  9. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement, Display Assembly: passo 9, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement, Display Assembly: passo 9, imagem 2 %32
    • Use the flat end of a spudger to pry off the two rubber hinge covers, one from each end of the device.
    Pergunte ao FixBot
    Comentar
  10. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 10, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 10, imagem 2 %32
    • Remove the two 3.1 mm T5 Torx screws securing the aluminum hinge covers to the upper case.
    • Remove the two aluminum hinge brackets from the MacBook Pro.
    Pergunte ao FixBot
    Comentar
  11. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 11, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 11, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 11, imagem 3 %32
    • Use the tip of a spudger to pry the display data cable lock and rotate it toward the DC-In side of the computer.
    • Pull the display data cable straight out of its socket on the logic board.
    • Do not lift up on the display data cable, as its socket is very fragile. Pull the cable parallel to the face of the logic board.
    Pergunte ao FixBot
    Comentar
  12. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 12, imagem 1 %32
    • Remove four out of the six 5.3 mm T8 Torx screws securing the display to the upper case.
    • We purposely have you leave one screw attaching the display to the upper case to aid in future steps.
    • When reassembling, make sure that the screws go through the two grounding loops on the webcam/airport cable.
    Pergunte ao FixBot
    Comentar
  13. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 13, imagem 1 %32
    • Open the MacBook Pro approximately 110 degrees, and place it sideways on the table, as shown.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the lower (closer to the table) display bracket.
    Pergunte ao FixBot
    Comentar
  14. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 14, imagem 1 %32
    • Be sure to hold the display and upper case together with your left hand. Failure to do so may cause the freed display/upper case to fall, potentially damaging each component.
    • While holding the display and upper case together with your left hand, remove the remaining T8 Torx screw from the upper display bracket.
    Pergunte ao FixBot
    Comentar
  15. MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 15, imagem 1 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 15, imagem 2 %32 MacBook Pro 15" Retina Display Mid 2012 Display Assembly Replacement: passo 15, imagem 3 %32
    • Grip both halves of the device, one in each hand.
    • Gently push forward on the bottom half of the device to detach it from the display assembly.
    • Carefully set each component aside, making sure to set down the lower half keyboard-side down.
    Pergunte ao FixBot
    Comentar
Conclusão
161 outras pessoas executaram este guia.
Jake Devincenzi
Membro desde: 04/18/11
119.362 Reputação
Autoria de 57 guias
12Comentários do guia
I found that this was a really easy project. even easier than replacing my iphone 5 screen. however the replacement screen I purchased from a third party did not have the wires for the webcam connected. they had been severed off. Also the antenna and connectors were not included either so I had to take them from the old broken screen. this was at first frustrating but then I thought about how often I use a webcam and quickly carried on with the project because I really don't need a webcam (and now the NSA can't see me hehe). also the plastic covering for the antenna which is talked about in the retina display teardown as easy to remove was in fact far more difficult for me to remove than anything. I ended up nearly breaking the plastic covering in half trying to remove it.
Overall, this was an easy and painless 2/10 difficulty to perform and had the cords for the webcam been present it would not have made it any more difficult. Piece of cake.
blaykeolson - Responder Compartilhar
Hi there. I see you noted the antenna cover was difficult. But can you remember how things are connected on thre antenna? I've just got a machine, and someone has broken all the antenna connectors. The antenna doesn't cost much but all come with isight cables too. I'm hoping you can just disconnect and remove the isight cable that comes with the new antenna and just connect the one that is already there.
Paul Saunders - Responder Compartilhar
Very easy thank you,
Most difficult for me was step 15 (to put back the new screen) and step 5 (put back the little things) but very easy actually !
Nico - Responder Compartilhar
i would like to thank you for the guide-very easy
Soul - Responder Compartilhar
Who rates these difficulty levels?
mayer - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 25
Últimos 30 dias: 173
Ao todo: 175,255
