Left ear side not working!
It only works when i twist the cord. I disassembled the left ear but there are no loose wires.
Esta é uma boa pergunta?
Sounds like the wire is broken inside the cable and thus you have a loose contact. There are really only two options to fix this:
- find the approximate location of the broken wire, cut it out and mend the resulting two ends together
- replace the whole cable altogether
Esta resposta foi útil?
Continuity test from speaker to jack to find the break, or as mentioned, replace the whole harness.
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Ao todo: 1,813
Also the left ear will work if i twist the jack
por Jannaeus Gabinete Compartilhar
